RGV VJ22 Rotors
Re: RGV VJ22 Rotors
Yes the VJ21 discs are smaller diameter(the quick guide is that the VJ21 disc carriers have round holes) The calipers and pads are the same as are the front wheels ,but pedantics will check the cast date at the base of the wheel spokes if you concourse it,its not just Italophiles who insist things are "correct".The rear wheel size for VJ21 is 18" and uses a different rear disc to Vj22,thicker and more surface. E.B.C.is one of many manufacturers who advertise O.E.M replacement products if you are unable to find ,or unwilling to use second hand items.Scrubber.
