hi
Re: hi
Yeah, good effort
If it aint smokin its definitely broken
- Regular Stroker
Re: hi
What is the usual course of action to remedy this type of failure?
Locate and rectify air leak.
Replace piston.
Hone bore.
Assemble.
Ride.
Am I oversimplifying the issues and other potential problems?
Replace piston.
Hone bore.
Assemble.
Ride.
Re: hi
^other piston
ive been contacting every forum and every guru i can for 'course of action'
the current plan is
new pistons
hone barrels
engine out to replace crank oil seals and clean out any melted piston bits
restore squish gap back to stock
colder plugs br9 change to br10
jet the bike properly- starting much bigger and plug chopping my way down before any further extended operation at WOT + redline
Re: hi
It wasn't a seizure, so a hone isn't *necessary*, but definitely a good idea, especially if you are changing rings.
Check for leaks and check again. Definitely go up in jet size. The other piston was close to going too. I thought I could see the other piston in the other pic, but it was just the bore
w3a51l, you're pretty close to the mark, aside from looking at jetting as well, once the bike is back together.
