KTMito 380
Re: KTMito 380
when you braked with the forks on the bike and rolling, did the fork leg make a sticking/grabbing noise? if so it could be the seals grabbing as the bushes are shot so the fork leg isnt riding up and down as it should. Ive had this with my KTM WP forks.
Re: KTMito 380
interesting.
I havent used these forks on the bike yet.
But when I pump them up and down when off the bike, they make a rubbing, squeaking noise
Ill be very happy if this is all it turns out to be... full rebuild/service, get the fork set up perfectly and then Ill be happy as a pig in shit :)
Re: KTMito 380
Ring inside the dust seal could be rusted as well
Re: KTMito 380
not dust seals, I popped them out and tested.
The fork only seizes when fork bottoms are turned in one particular direction, which to mean is a standout symptom of bent forks
Re: KTMito 380
I would think a bent fork would make a noise no matter which way round the bottom was turned, the bent part would still be interfacing with the non bent part at the same point in the stroke, just a different orientation.
Re: KTMito 380
hmmmm fair point also.
We shall soon find out, I will be dropping it in for a rebuild this week hopefully :)
Re: KTMito 380
Keep us posted Jeram, fingers crossed it wont be anything serious mate.
Re: KTMito 380
no worries,
I did a quick search on google for 'forks stuck' and of all the results to pop up, most we from the aprilia forum with people who had seized bushes and seals.
Maybe ill be in luck!
Ill keep you all posted.
Re: KTMito 380
confirmed, forks bent.
2mm on the upper, 2.5mm on the lower :(
Luckily I didnt send it for a rebuild as it would have been 300 bucks down the drain
Luckily lozza has a spare RHS fork which he is going to check straightness of and let me have for a reasonable amount :)
Re: KTMito 380
bummer indeed. Mine squeaks and I know the bushes are dead as they are worn and just pull out without any hesitation, so was hopeful yours might be the same. The fact it sticks down was a bad sign tho :(
Re: KTMito 380
forks are in getting worked on at promecha, Peter at promecha found a dent in the fork upper so ill be sourcing a new upper from lozza or converting one of his good left legs into a right leg :)
Re: KTMito 380
My mate is giving it a spin in the lathe to make certain it's straight
Re: KTMito 380
nice one Lozza :)
Re: KTMito 380
Woohoo, My forks will be rebuilt, upgraded and ready to go in one week :)
Re: KTMito 380
Been quietly busy since my last post.
Made a crankshaft starting system so that the bike can be fired up using a handheld starter motor.
Got my forks straightened, re-valved, re-sprung and serviced. They feel great now.
Just need to spit these 3 parts out on a CNC machine after new years and then I'm ready to ride :)
2 are my new front caliper bracket designs which I put together 2 weeks back
The other is the long awaited rear caliper offset bracket which I did yesterday
