Page 9 of 10
Re: KTMito 380
Posted: Sat Aug 30, 2014 11:47 pm
when you braked with the forks on the bike and rolling, did the fork leg make a sticking/grabbing noise? if so it could be the seals grabbing as the bushes are shot so the fork leg isnt riding up and down as it should. Ive had this with my KTM WP forks.
Re: KTMito 380
Posted: Sun Aug 31, 2014 12:42 pm
interesting.
I havent used these forks on the bike yet.
But when I pump them up and down when off the bike, they make a rubbing, squeaking noise
Ill be very happy if this is all it turns out to be... full rebuild/service, get the fork set up perfectly and then Ill be happy as a pig in shit
Re: KTMito 380
Posted: Sun Aug 31, 2014 3:07 pm
Ring inside the dust seal could be rusted as well
Re: KTMito 380
Posted: Sun Aug 31, 2014 4:05 pm
not dust seals, I popped them out and tested.
The fork only seizes when fork bottoms are turned in one particular direction, which to mean is a standout symptom of bent forks
Re: KTMito 380
Posted: Sun Aug 31, 2014 10:52 pm
I would think a bent fork would make a noise no matter which way round the bottom was turned, the bent part would still be interfacing with the non bent part at the same point in the stroke, just a different orientation.
Re: KTMito 380
Posted: Mon Sep 01, 2014 9:15 am
hmmmm fair point also.
We shall soon find out, I will be dropping it in for a rebuild this week hopefully
Re: KTMito 380
Posted: Mon Sep 01, 2014 9:28 am
Keep us posted Jeram, fingers crossed it wont be anything serious mate.
Re: KTMito 380
Posted: Mon Sep 01, 2014 11:10 am
no worries,
I did a quick search on google for 'forks stuck' and of all the results to pop up, most we from the aprilia forum with people who had seized bushes and seals.
Maybe ill be in luck!
Ill keep you all posted.
Re: KTMito 380
Posted: Mon Sep 01, 2014 8:49 pm
confirmed, forks bent.
2mm on the upper, 2.5mm on the lower
Luckily I didnt send it for a rebuild as it would have been 300 bucks down the drain
Luckily lozza has a spare RHS fork which he is going to check straightness of and let me have for a reasonable amount
Re: KTMito 380
Posted: Mon Sep 01, 2014 11:43 pm
bummer indeed. Mine squeaks and I know the bushes are dead as they are worn and just pull out without any hesitation, so was hopeful yours might be the same. The fact it sticks down was a bad sign tho
Re: KTMito 380
Posted: Mon Sep 15, 2014 4:50 pm
forks are in getting worked on at promecha, Peter at promecha found a dent in the fork upper so ill be sourcing a new upper from lozza or converting one of his good left legs into a right leg
Re: KTMito 380
Posted: Thu Sep 18, 2014 12:11 am
My mate is giving it a spin in the lathe to make certain it's straight
Re: KTMito 380
Posted: Thu Sep 18, 2014 5:15 pm
nice one Lozza
Re: KTMito 380
Posted: Fri Oct 10, 2014 8:57 pm
Woohoo, My forks will be rebuilt, upgraded and ready to go in one week
Re: KTMito 380
Posted: Sat Dec 20, 2014 7:35 pm
Been quietly busy since my last post.
Made a crankshaft starting system so that the bike can be fired up using a handheld starter motor.
Got my forks straightened, re-valved, re-sprung and serviced. They feel great now.
Just need to spit these 3 parts out on a CNC machine after new years and then I'm ready to ride
2 are my new front caliper bracket designs which I put together 2 weeks back
The other is the long awaited rear caliper offset bracket which I did yesterday
