RGV parts needed
Looking for a part?
RGV parts needed
I need the following parts for my VJ22 M model
The bracket that holds the tank and seat to the frame
The two brackets that hold the fairing side panels to the frame where your knees would be.
Cheers Pat.
Lohoon
Re: RGV aprts needed
Post by Lohoon »
Hey pat, they're is no bracket to hold side panels.its built as pat of the rear subframe. As for the other bracket,I made one just the other day. Its a flat piece of steel with 2 holes in it and a nut welded in the middle.the seat bolt goes in the middle, the tank bolts go in the side ones first
I meant the front side panels for the fairing and the brackets around the Carb area.
