who makes custom pistons is aus for old smokers
Just trying to find somewhere that makes custom forged pistons for 2t,s these days i mean it i just want 1 or 2 not a shit load.tried wiseco no result.
Re: who makes custom pistons is aus for old smokers
yes Wosner, but you need to buy 4 at $200 a pop
And you will need to send them either cad drawings or a piston to copy.
Thanks guys i will give them a call.
Contact wosner online via online enquiry.
If its for the kr there are other piston options mate, just speak to people with experience with KRs. There are plenty of options
I have a matr at a bike shop who said he has a list and they just cross refrance the sizes he also said wossner were a good thing.i just want to find pistons before i pull it down its still going but its just down on comp are thease 84 kr,s nical plated bores?
all you need is
-matching bore size (or larger if you want to bore it out and replate)
-matching piston pin size (or adapt it with different small end bearings
-matching skirt length (or longer) this is usually done by simple finding a bike with the same stroke or longer
-same compression height (taller will require you to make a spacer plate to go under cylinder, shorter will require you to machine the cylinder base.
check if your piston is worn, if the piston is OK I would consider just buying rings from YAHOO JAPAN auctions and putting them in your current pistons
I wish i could find a kr piston to meshure without takeing mine out.it would suck to pull you engine apart onley to find you cant get any pistons i wonder how many kr owners have done that lol i am almost affraid to know what my internals are like.
you're better off doing a compression test to check the rings, pill the cylinder off and inspect the piston and bore.
If everything is OK (piston isnt worn/damaged), clean everything thoroughly, install new small end bearings and put it back together!
[quote="Jeram"]you're better off doing a compression test to check the rings, pill the cylinder off and inspect the piston and bore.
If everything is OK (piston isnt worn/damaged), clean everything thoroughly, install new small end bearings and put it back together![uote] i agee i have a gasket kit on its way from japan i was thinking just replace the crank seals / rotery valve seals head and base gaskets/water pump seals
if thats all it needs, then thats all it needs
Hi What bike is it ?
We have both CAD services & pistons.
Let me know what you need & I'll see if we can help ?
Regards
Steve
F1 Moto
02 4631 2599
Regards
Steve
F1 Moto
02 4631 2599
