ged wrote:
Is that the plating showing there or bare metal?
The phot was taken at night and either me or the camera ain't good enough - but it is OEM nickle plating, and looking goood
I am a wanker
- I get suckered in every time.
Same this time - I saw the frame an concluded "the nickle is stuffed - I won't stuff around with that". But then.........
I saw all this hardened years old chain lube on the frame and thought "Yeah, I'll squirt that with some degreaser and hose it off"
Left overnight the degreaser didn't even dent the crud.
"okay tough guy, I'll squirt you with some WD and use a screw driver" - Yeah take that; that worked.
"I wonder what it will do if I used WD and nylon scrubber" - "hey, that's looking pretty good".
"I wonder what these tubes will clean easily" - "hey, that's looking pretty good".
...........and so I got suckered in, again.
But I have come to the conclusion the frame can be made to look pretty good - a lot damn better than it is now. Even acceptable - I think the worst (and the best) will end up behind fibreglass bodywork.
And I think the finish can be improved (more effort). I haven't used metal polish of any type yet, just WD, Nylon scrubber and elbow grease.
The good and the bad can be seen here.
The welds come up good hey, I wonder why
The swing arm and side stand are the big issues. So I thought "okay, I'll take the swing arm and show BluChrome and ask them "how much?".
Now another job I hadn't intended to muck with - if it ain't broke......
And the pivot bolt is stuck ::).
