2T DI/Jet Ignition Research Paper.
Recent thesis from local facility, RMIT https://researchbank.rmit.edu.au/eserv/ ... /Jiang.pdf
Re: 2T DI/Jet Ignition Research Paper.
Heavy reading. What are the real chances of seeing RD350LCR ?
Reckon we'll have mainstream electrics before we see another stroker :-/
Hydrogen?
Thanks.James W. wrote:Recent thesis from local facility, RMIT https://researchbank.rmit.edu.au/eserv/ ... /Jiang.pdf
An interesting article. Here's something on Jet Ignition.
http://www.motorsportmagazine.com/opini ... t-ignition
Nothing new under the Sun hey!!!
Looks like tech that could be retro fitted for a 30% gain . Old plug out - screw in the dovalackie. Just need the place and electrics for a humungous fuel pump.
Thanks for those links great reading . Taking a already highly developed race engine from 870 to 950hp is a very significant achievement. Pity RMIT didn't only simulated the combustion and never built a test engine
OzzyElsie wrote:Thanks.James W. wrote:Recent thesis from local facility, RMIT https://researchbank.rmit.edu.au/eserv/ ... /Jiang.pdf
Now, if you had an RD LC, you could use the massive hollow space under the fuel tank (that is occupied by the stock air box)
to locate such a pump. Orbital Corp might even spring one to you, for research purposes..
