RZ350 Hybrid
gman
Re: RZ350 Hybrid
Post by gman »
I think that colour scheme or a varient of it will work out well, I like the black on the bottom with the white yamaha decal.
It's a good feeling when you can start assembling clean / new parts and see the bike taking shape.
Re: RZ350 Hybrid
phil1rowe4 wrote: Sat May 27, 2017 11:30 pm Someone sent me this picture which is very close to the look I'm going for.
Anyway, I've been working on the frame while waiting for engine parts to arrive and got the frame finished today.
I can now start bolting bits on permanently so I'm pretty chuffed!
Yeah, I like that a lot!
phil1rowe4
Re: RZ350 Hybrid
Post by phil1rowe4 »
Shiny bits being attached.
phil1rowe4
Re: RZ350 Hybrid
Latest Update:
Re: RZ350 Hybrid
Looking very fine indeed Phil
Re: RZ350 Hybrid
phil1rowe4
Re: RZ350 Hybrid
Latest Update: Front forks refrurbished with new seals and bushes.
Front callipers rebuilt. Lots of little clean/paint/fit jobs now.
gman
Re: RZ350 Hybrid
Post by gman »
Good progress phill. excellent build quality. Are you using the original rz side stand? Allways wondered how much the frame is lowered with the rgv suspension /wheel combination?
Re: RZ350 Hybrid
Your speed of progress and workmanship makes the rest of us look pretty slack :evil:
Re: RZ350 Hybrid
Fine work Phil
Re: RZ350 Hybrid
Looks great!
phil1rowe4
Re: RZ350 Hybrid
Thanks for the positive comments, any encouragement helps!
Gman, the forks are slightly shorter than stock so the front is a little lower but the rear height is determined by the dog legs which I've made to suit the ride height I wanted. Standard side stand luckily works well. I'm thinking of fabricating a new one to fix some clearance issues with the gear shifter, so will have to see how that turns out.
I'm also planning to fabricate some replacement rear sets as these are chinese ones and are flexing a bit.
Progress looks fast as these are all the big bits! I'm into the smaller bits now so changes will appear slower. I do try to do something every night and most weekends, so have a very understanding missus. Helps that I can do 95% of the work myself, just have to wait for bits to be delivered from overseas!
phil1rowe4
Re: RZ350 Hybrid
Progress shots. Lots of little jobs. Mounted custom oil tank, fabricated a battery box, repainted switchgear & fabricated a dash for new instruments. (cardboard template in photo).
Waiting for Zeeltronic ign and other bits to be delivered before starting to redo the wiring loom.
[url=https://flic.kr/p/VaCELb]Image[/url
[url=https://flic.kr/p/VaCELw]Image[/url
phil1rowe4
Re: RZ350 Hybrid
Photobucket has changed their terms of use and have now blocked photo references in other sites (forums) !!
Major pain in the butt to move all my pics to Flickr and edit all my previous posts. I'm working on it but may take some time.
In the meantime, latest update is that front brakes are all refurbished, repainted and working. :)
Rear caliper refurbished and just waiting on master refurb kit to arrive.
Engine completely finished and holding oil so far. Cooling system to be filled tomorrow.
Ignition switch fitted with a spacer I made on the lathe and handlebar switches cleaned up and repainted.
Dash and instruments fitted. Zeeltronic and dyna coils arrived and just waiting to be mounted and wired in.
I'm waiting on some electrical connectors and fuse box to arrive and then will start on the re-wiring.
After the wiring, I should be able to start the motor. eek!!
[url=https://flic.kr/p/VdtczB]Image[/url
[url=https://flic.kr/p/Vdtcy4]Image[/url
phil1rowe4
Re: RZ350 Hybrid
Started on the rewiring so, all going well, should be able to start the bike this weekend or next.
