Need one, with a good ball bearing thingo that stops the lever from rotating out as you ride.
Sydney.
Cheers.
RZ350 Kickstart Lever
If people quit riding after a crash, there'd be nobody left riding!
Re: RZ350 Kickstart Lever
hard to find one that isnt flogged out. you do know you can buy a rebuild kit tho?
The rebuild kits from Yambits are quite good but on my RD400G, I used their spring and ball with the original washer and E-clip, as their parts didn't look quite right.
Rgds
Rgds
you can also slide another thin washer in there at times. but.... they do wear the shaft and the lever's hole, you cant fix that easily.
