nsr150sp
Posted: Sun Oct 17, 2010 10:57 pm
by HM31A
anyone shed some light on these bikes
any problems to look out for
and where could i track down a workshop manual
cheers mike
Re: nsr150sp
Posted: Mon Oct 18, 2010 10:22 pm
Based on the old NF/CR engine with a 58/59mm(can't remember) piston. Pistons are not the best and the needle in the carb has no adjustment. Rear shock is crap the rest is OK. Not a bad little bike really.Parts are cheap from Thailand
Re: nsr150sp
Posted: Fri Dec 07, 2012 8:54 pm
by HM31A
anyone a 150 expert here
as the one i have has got a vibration in the engine when reving so when riding its horrible
thanks in advance
Re: nsr150sp
Posted: Fri Dec 07, 2012 9:16 pm
Balance shaft not timed.
Re: nsr150sp
Posted: Sat Dec 08, 2012 8:14 am
by HM31A
thanks for the prompt response
would they go out of timing by themselfs as the engine has not being touch or do they have an underling issue
Re: nsr150sp
Posted: Sat Dec 08, 2012 10:54 am
if they balance shaft is a one peice unit cast unit then there is no way for it to go out of timing.
it should just be a matter of taking the clutch cover off and inspecting the balance shaft gear. the gear will most likely have a dimple of mark in it, the gear which connects to it (usually the primary gear) should have a similar mark on (timing marks) the two dots should line up.
if it doesnt have markings then buy the bikes workshop manual and it will most likely be in there.
if its not the balance shaft it could only really be the bottom end bearings.
Re: nsr150sp
Posted: Sat Dec 08, 2012 7:31 pm
by HM31A
thanks for that
bike starts easy so hope its not the bottom end
Re: nsr150sp
Posted: Sun Dec 09, 2012 9:09 pm
engine mounts loose?
Re: nsr150sp
Posted: Sun Dec 09, 2012 10:14 pm
by HM31A
2TInstitute wrote:engine mounts loose?
yeh
i thought that
will check
thanks for the thought
