fitting Boysen reeds to a Mito
doobie
Post by doobie »
when fitting Boysen reeds to the Mito, is it a straight swap for the original reeds? will i need anything else to fit? :?:
Re: fitting Boysen reeds to a Mito
A V Force reed block :wink:
maddad
Post by maddad »
yes i need more mito stuff.good luck
+1 Vforce
otherwise, If your just buying reeds make sure they are disigned for the OEM mito reed cage...
If you are buying a whole boysenn reed cage for the mito, it should bolt right on plus some jetting changes to the carb
but I would recommend ditching the boyesen rad valve and getting a vforce too
