banshee top end
Got some parts to sell?
twinrock
banshee top end
Post by twinrock »
i have a professionally(jmc racing) ported top end for a banshee/rz it is still on original bore how ever one side has suffered minor damage due to big end fail the next over size will clean it up and u will need a new piston
this was an awesome top end it made great power through out rev range.. i have 2 mates with semi stock rz350s and this pulled much harder i would compare it to the athena top end with the stroker crank i had but more bottom end and not as peaky power delivery..
a good simple up grade..
$600 firm and im loosing money at that..why would u spend $600 on this when you can buy an athena for $800 you ask.. i had an athena kit and the same reason i went this way..reliability..something goes wrong u can always rebore..all of the plated banshee after market stuff will eventually wear or if become damaged..expensive to replate..0406726252 thanks
South_Oz
Re: banshee top end
Post by South_Oz »
Wish I had the $$$ but between jobs ATM. Good luck with the sale. PM sent.
Dave
