RD250LC
Re: RD250LC
Just wondering has anyone else had issues trying to get the bottom and top bearings races out of the head stem? there's no lip to sit the drift on to knock them out, anyone got any ideas?
Re: RD250LC
yeah it happens. usually you can find a lip somewhere, and any good mechanic should have ground a little of the frame back before installing cups that have no lip, but if not you may need to either weld a bar or some blobs on the race, that heat can help get it out if not hit the weld. Its gutting when people do this :/
Re: RD250LC
A mate of mine just recently did his steering head bearings on his KDX250 and all he did was hit the faces of the old cups with a MIG and run a few beads and they fell out when they cooled.
I usually weld a bit of crap over mine and then use a long drift, but I might try the other way next time.
Re: RD250LC
Yeah it's a bitch of a job. Mine was a long time ago, but I'm sure I managed to get just a bit of purchase on the bearings by going in through the opposite end of the head stock. After a bit of messing about, it was enough to get them to move and come out.
Re: RD250LC
Ive always managed to find the meerest of lip from the b-side and used that like you Jeff, but ive heard welding is the way otherwise.
Re: RD250LC
thanks guys, there was no lip at all to catch the drift on, couldn't make them move at all.
I don't trust myself welding either so I dropped the frame to Lloyd Penn in Artarmon, the guys there got them out for me for $50.
Re: RD250LC
Hey guys, i've been overseas the last month so been a while since i've posted, i've just installed the bearings in my wheels and i've found that the spacer inside the back wheel is loose inside the hub, i'm guessing it shouldn't be that way?
the front wheel is fine, the spacer doesn't move around at all.
Re: RD250LC
Shouldn't be loose no. Are the bearings in all the way?
Re: RD250LC
yeah the bearings are all the way in, I checked the Haines and I think I'm missing the right side flange spacer, anyone know where I can get one of these?
Re: RD250LC
Lloyd Penn must be looking old these days, all the couriers, me included, in Sydney used to use him in the 90's. Good workshop.
