Well apparently 'shee cases have no engine numbers stamped on them. I don't think your the type to do anything sneaky like restamp the 'shee cases with the LC engine numbers Pete, so the authorities are none the wiser would you? ;) ;)
Looks like there is a shit load of room in there for a big airbox, should be sweet.
Athena BIG BORE is here !!!!!
Sweet, this will end up being something pretty special. Order a 5mm spacer plate from Steve when you have a chance
Pics of ATHENA kit
Athena Head with Inserts
(196.63 KiB) Downloaded 120 times
Athena Heads
(212.38 KiB) Downloaded 120 times
Athena Barrel
(163.1 KiB) Downloaded 122 times
Athena Full Kit as received
ATHENA BIG BORE KIT
(206.66 KiB) Downloaded 119 times
Antman
Post by Antman »
No speedo pick up on shee cases just a thought.
What did the complete Athena kit cost you landed in Oz?
Cheers Ant
Hmm Steve's or blank inserts and the clutch would be sweet. NSR has the same swing arm to I think.
You don't want to know how many ponies these will punch out. :)
twinrock
Post by twinrock »
hey mate u will be vey appy with the athena kit mine was a blast..awsome..
the 600 swingers are steal not sure if u noticed..i would us a tzr or fzr(the alloyone) your front end of the 600 will bolt straght on no mods but im pretty sure the rear is a wheel is 18 inch
Do as many arm strengthening exercises as possible because your going to need every bit of strength to hold onto it when it hit's band.
