JonW wrote: ↑Mon May 08, 2017 10:33 am
The RZ front end is a simple drop in on an LC, so that shouldnt worry you if you wanted more lock... so here is my 2c:
My restored/emended LC has an RZ mk1 front end - marked improvement - the OEM front forks were a backward step from the RD's.
- the mead speed seat could be trimmed to match the side panels and then it would be slimmer overall, its huge as it stands. horrid.
I agreed. I was thinking of cutting and trimming but it is a lot of work and I ain't certain it will turn the pig's ear into a silk purse. One option is to sell it and put the time into the LC tail which I think is a proportionally better starting point.
- the tank is massive. wasnt Mel Lemoto a racing guy? seems like this is a long range thing. I dislike it, but im torn on this... you wont see another, which makes your bike different, hence i would use it
I agreed although it ain't too bad - and an LC fitting tanks are like honest politicians, hard to find and expensive to buy.
I don't think the lemoto looks too bad or as big in the flesh. It's a neat fit and it looks LC specific but i think it is a factory adaption from maybe a TZ. It is fat at the front which leads to the triple issues. It has deep sides without a cross over tube and one fuel tap so its an issue that probably needs to be addressed. With about 3-4 liters/3-4kgs potentially trapped in the RH side pretty much defeats the weight saving of the alloy tank.
It also has welded on hooks at the front for a quick release strap mounting and no mounts conforming to the OEM mounts - hang over from another design -- more work and head scratching.
 I dislike the cafe thing, especially if its irreversible, but its not my bike.
Any style can be tasteless, any style can be stunning - I ain't hang up on a particular style. The style is more determined by taste and what I have available to me. I ain't got any rules about reversibility but I generally refrain.
Ah, buy in haste, repent at leisure
