JonW wrote:Lozza i was told the innards of the RGV RWU forks are the same as the USDs, if so then the ones you found may well work?
I wouldn't believe that person any more, the RWU RGV fork is just a plain damper rod fork. USD would be the same principal but not the same internals.
The best set of 250 forks are the Aprilia RS250 Mk2 Showa's :wink:
And started to sort out the undertray and rear lights (cause I cant do anything up front now till I get the shocks back and some new bearings)
(166.58 KiB) Downloaded 131 times
blimey you have been busy Pete... I should have dropped down and helped, its peeing with rain here, cant do anything :/
ok, good call.
Hmmm... Do the 'prilia forks fit the RGV triples?
Bummer on shock man... id have been annoyed if you went all the way there :/
Ahh yes the perennial build, dismantle, change, rebuild cycle... I know it well... its the curse of doing custom bikes... much simpler to restore! LOL
Motogadget arrived today and first impressions..........tiny !
Have a look at it beside my garage opener.
from behind
from behind
motogadget back.jpg (184.8 KiB) Viewed 4231 times
knife
knife
motogadget knife.jpg (182.6 KiB) Viewed 4231 times
front
front
motogadget front.jpg (171.58 KiB) Viewed 4231 times
WOW! I love it! I cant wait to see this unit. amazing.
hmm... is tiny a good thing for what you wanted?
Eeek... At least he was willing to negotiate, that's crazy for him to do that without so much as a phone call. In the UK if the dealer does work or replaces parts that you didnt sanction you can have them for free. Most poeple accept a small variance on a quite, like you did, but more than double is mental.
Fark me!Wouldnt want to bend those puppies.....
I was waiting to see how you went with this,think I will go the Andreani way too.....
Where can I find fork tubes in Oz?
