I tried it, Its alright but nothing like the real thing.
you can tell its fake a mile off.
It was delivered today. Nice size sheet, should have enough for a few 'failed - try again'
To be frank I'm not certain what carbon fibre should look like but I'll treat it like an alternative finish and see what it looks like. This looks like weave embossed vinyl.
There are 'how to' vids on Utube. Should be interesting.
some of this looks good, just scroll down the page , abit like that lino in the kitchen that looks like slate, you know its not slate but still looks ok
place it over your airbox for instance, use head to shape it, then cover it in several coats of rattle can clear. it will look pretty horn.
just done cover bodywork in it, it looks poxy.
other things you can use it on: bits of your frame that get scraped by your boots, under seat trays, guage cluster etc.
just use it sparingly and you may like it.
20 bucks for that size a sheet sounds like the cheap stuff, I bought 3M di-noc off ebay and it was $20 for 2 A4 sheets
What's the point? The whole idea of carbon fibre is that it's light and strong. If you're just adding a layer of faux carbon you're actually making that bit HEAVIER...just sayin'...
If people quit riding after a crash, there'd be nobody left riding!
Lowflying wrote:What's the point? The whole idea of carbon fibre is that it's light and strong. If you're just adding a layer of faux carbon you're actually making that bit HEAVIER...just sayin'...
Faking it before you can make it .
Bling!!! For appearances only. A $2000 paint job is no faster then a $20 matt black rattle can job either
