Re: Introduction
Posted: Mon Aug 19, 2013 4:52 pm
Liam,
this might help you
http://2-stroke-porting.com/Terminology.html
this might help you
BlowDown - Measured in degrees of crankshaft rotation from Exhaust Port opening to the Transfer Ports opening.
BlowDown TA - Must allow the cylinder pressure to drop below the pressure of the fuel air mixture at time of transfer ports opening. If the Blowdown pressure is to high when transfer ports open, it will stall or reverse, the incoming charge of fuel and air.
