Removing oil Injection. Ds7 r5 etc
Re: Removing oil Injection. Ds7 r5 etc
Heh heh heh ;-)
The worm is retained by a nut on that model. You need to take off the r/h case to remove it. A new seal for the worm shaft will also be required.
Thanks arrow. Any where I can purchase either or both seal. And r5 worm shaft?
The wormshaft seal is still available from Yamaha. Wise to replace the kickstart seal too. Good luck with the wormshaft. I will look out for one if you want?
http://www.ebay.com.au/itm/Yamaha-Oil-p ... XQgb1RO-wy
I found this on ebay its a course 6 thread worm.
i checked my ds7 and it has a course 6 thread also
OK i think i have worked it out Arrow.
The R5 gear drive (white plastic cog) has 21 tooth drive and the ds7/rd250 has 22 teeth.
so both would use the same worm just different gear drive?
As I have said before, I don't confess to know all the worm drive arrangements on the early bikes, suffice to say it would surprise me greatly if the ds7 and r5 worm were the same. You can't run the 21T gear on the ds7 as the primary gears are different between the two bikes.
