gday from brissy, new here
ken007
Re: gday from brissy, new here
Post by ken007 »
hey doco, do you recognise the seat,? thanks again, i will get it recovered in a couple of weeks, thanks again.
Polished bowls, mmmmmm.
Geez I didnt notice the seat at first actually, well glad that worked out then.
ken007
Post by ken007 »
well the latest is not good, put oil in the gear box and it leaks from where i had some welding done to some earlier chain damage so am looking for a pair of engine crank case covers , i also need the top one aswell because were the kick starter assembly goes the bit where the return spring goes is busted off, i have a add in the wanted to buy section and would appreciate any help in this matter, just when i could see the light at the end of the tunnel now this, its been set back after set back, anyway its been charactor building to say the least, thanks in advance, ken
ken007
Post by ken007 »
sorry ,i only need a lower case ,for some reason i thought the kick started was on the top one, thanks
Ken, FYI its always best to get top n bottom cases together as they were lined bored when new, hence the engraved numbers that prove the top n bottom match...
ken007
Post by ken007 »
thanks for that jon, have you got some spare ones, lol
