Page 27 of 32
				Posted: Mon Feb 20, 2012 12:03 pm
				Best option is Aprilia Showa forks (RSV/RS 250) all the hard work is done for you.
Hope the forks are worth it Pete.
				Posted: Fri Apr 13, 2012 12:47 am
				by DOC03
				Posted: Fri Apr 13, 2012 10:42 am
				Thats bizarre Pete... try and knock the spacer to the side to create more of a gap there, if that fails i guess you will have to remove the inner race and then you would have access to the other side as you could remove the spacer, then get the last of the first one out...
Also you could try a a split style bearing pusher. I have one, if you want to drop over with a wheel one day we could give it a go. In the meantime try a rawl bolt, you never know it may work. do it tight and hammer like hell from the other side after heating the wheel of course.
				Posted: Fri Apr 13, 2012 12:04 pm
				Pete this is the bearing remover set i have (currently on special)
http://www.torpedo7.com.au/products/T7T ... et---9-pcs
				Posted: Fri Apr 13, 2012 12:33 pm
				by ken007
				jon, have you used it much,? does it do a decent job?
				Posted: Fri Apr 13, 2012 2:02 pm
				Ive used it a few times, worked ok. you need to make sure the splitter rod is well fitted to the die, but ive removed a few things with it now and its saved some heartache with some hard work bearings, but im sure their bigger tool is better and there are others on the market of course.
				Posted: Fri Apr 13, 2012 2:25 pm
				by DOC03
				Posted: Fri Apr 13, 2012 2:42 pm
				eeek. well offer if there if you want to pop in on way home m8, im happy to see if we can make it happen, but you will have to do the hitting, ive trashed my elbow :/
				Posted: Fri Apr 13, 2012 10:03 pm
				Pete you need a bearing puler with a split collet and a slide hammer. Remember to use a bit of never seize when you install the new ones.
http://www.ebay.com.au/itm/Blind-Bearin ... 27bf0cf1a0
				Posted: Sat Apr 14, 2012 1:20 am
				by DOC03
				Posted: Sat Apr 14, 2012 10:09 am
				LOL, well it will come in useful for the future...
				Posted: Mon Apr 16, 2012 3:14 pm
				by L.B.
				For future reference,if the guts of the bearing has been knocked out,run a weld around the inside of the bearing shell,the thing will fall out garanteed!
				Posted: Fri Jan 04, 2013 7:46 am
				by DOC03
				Posted: Fri Jan 04, 2013 8:09 am
				by DOC03
				Posted: Fri Jan 04, 2013 8:10 am
				by DOC03
