That looks like being a very special special when finished. Can't wait to see it complete!
Re: RZ350 Hybrid
Posted: Fri Jul 14, 2017 10:08 pm
by L.B.
Awsome work Phil its really coming along nicely.
Re: RZ350 Hybrid
Posted: Fri Jul 14, 2017 10:36 pm
by phil1rowe4
Thanks Oz & L.B.
It's getting to the exciting part soon... starting for the first time!
(I just want to shorten the exhaust pipes and angle up the mufflers while they're still clean inside, before I start it.)
All Ign and Instruments wiring finished tonight, so I could technically start it. Just the lights, blinkers, switch electrics to go.
I'll have to learn how to post a video of it running.
Re: RZ350 Hybrid
Posted: Sun Jul 16, 2017 12:16 am
by phil1rowe4
Here's some shots of the exhaust being shortened.
First pic has one pipe in the old position and one in the new position.
Second shot is the pipes in the final position and ready for fuel and some kicks tomorrow.
Re: RZ350 Hybrid
Posted: Sun Jul 16, 2017 9:49 am
Coming along nicely mate. It's going to be a nice one.
Re: RZ350 Hybrid
Posted: Sun Jul 16, 2017 7:07 pm
by phil1rowe4
It lives.....
Re: RZ350 Hybrid
Posted: Mon Jul 17, 2017 12:01 am
by L.B.
2nd looks heaps better.
2nd kick or 3rd loll.
Re: RZ350 Hybrid
Posted: Mon Jul 17, 2017 5:24 pm
by Ozhammer
Nice one Phil, she sure sounds sweet mate.
Re: RZ350 Hybrid
Posted: Tue Jul 18, 2017 3:07 pm
by phil1rowe4
Thanks L.B & Oz,
It seems to be running very rich as the plugs are wet, but at least its running. Lots of smoke out of one side and bugger all out of the other so some tweaking to be done. I wonder how tolerant my neighbours are going to be with all the white smoke !
Re: RZ350 Hybrid
Posted: Tue Jul 18, 2017 5:16 pm
White smoke... hmm.
Which side is more smoke coming out of? If it's the right hand side, you could have a bad gearbox seal and it's burning gearbox oil.
Re: RZ350 Hybrid
Posted: Tue Jul 18, 2017 10:12 pm
by phil1rowe4
It's the left side when sitting on the bike that's smoking more than the right. Both plugs are wet though. I thought it could be the oil pump so was going to disconnect the pump and run pre mix to help get the carbs setup.
Hadn't considered gearbox oil but cant see how it could get to lhs cylinder.
Re: RZ350 Hybrid
Posted: Tue Jul 18, 2017 11:15 pm
by phil1rowe4
Ive just done a quick compression test and both sides are the same. I also put my finger over the gearbox oil filler hole while I cranked it over and didnt feel any pressure or suction. Ive disconnected the oil feed tubes and blanked the carb feeds and will try it tomorrow with premix. If its still smoking more on one side then I might have a problem!
Re: RZ350 Hybrid
Posted: Wed Jul 19, 2017 9:41 am
All good if it's the left side. There is no way for oil to get in there.
Normally 2smoke oil has a blue tinge to it. White is normally not a good sign.
If it's a brand new engine, there could be some excess lube in there that was splashed around during the build.
If the oil pump is set up right, I would be surprised if it's that. They're pretty reliable.
The other possibility is coolant. But you'd get excess pressure in the cooling system if you were getting coolant in the combustion chamber.
Re: RZ350 Hybrid
Posted: Wed Jul 19, 2017 2:04 pm
by phil1rowe4
Tried with premix and much less smoke at idle.
Also found the right carb idle circuit not working properly so rhs cylinder only comes on properly when the needle comes into play. Then both sides smoke evenly.
Off with the carbs and try 25 pilots as current it idles smoothest and comes off idle best with air screw fully in.
Re: RZ350 Hybrid
Posted: Thu Jul 20, 2017 10:30 am
by Ozhammer
Might be worth sending the oil pump to Arrow on the RDLC site Phil, just for the peace of mind.
Just got mine back from him and it is honestly better than new and a very reasonable price.
