Page 5 of 6
Re: RZ250 Rebuild!
Posted: Mon Aug 22, 2022 8:52 am
by casabonka
And some more!
Just decals and clear to go!
Re: RZ250 Rebuild!
Posted: Mon Aug 22, 2022 10:51 am
great work!
Re: RZ250 Rebuild!
Posted: Mon Aug 22, 2022 10:58 am
by CNKXU1
Inspiring
Re: RZ250 Rebuild!
Posted: Sun Sep 11, 2022 6:45 pm
by casabonka
So close to completion now!
Bit of touch up to the rear fairing, ready for the grab rail, mirrors to go back on, finish off the windscreen and then off to get a blue slip.
Re: RZ250 Rebuild!
Posted: Mon Sep 12, 2022 11:21 pm
by Ozhammer
More great work Casa, trouble is they always ‘look’ finished, long before they ever are…..
Re: RZ250 Rebuild!
Posted: Tue Jan 17, 2023 10:41 pm
by casabonka
Hi guys!
Been a while between posts. From being on its way to get a blue slip and the engine dying on the way, we’ve been chasing an electrical issue which has seen us replace the cdi and ignition coil but with no luck.
Does anyone know what the power/voltage output readings of the CDI should be?
Re: RZ250 Rebuild!
Posted: Wed Jan 18, 2023 10:50 pm
Does it only do this when warm? If so I'd suspect the stator. Try swapping that out.
Re: RZ250 Rebuild!
Posted: Thu Jan 19, 2023 11:23 am
by casabonka
JonW wrote: ↑Wed Jan 18, 2023 10:50 pm
No, it started, and then died and hasn’t started since.
Tested all elements stator, CDI and coil and all 3 seem to show a power reading, but not sure if the values are correct. Absolutely stumped now.
Re: RZ250 Rebuild!
Posted: Thu Jan 19, 2023 1:55 pm
I assume when you kick it over there is a spark? if not its likely the kill switch circuit...
Check all the connectors and make sure when ignition is on that the kill switch wiring isnt earthing.
And... check the switches? check the ignition and the kill. Both can cause intermittent issues
Re: RZ250 Rebuild!
Posted: Mon Jan 23, 2023 9:09 am
by casabonka
JonW wrote: ↑Thu Jan 19, 2023 1:55 pm
Thanks mate, checked that out and gave it a clean and a test, but still no luck. Looks like the replacement ignition coil I got was dead also. Have ordered a new one from the UK, but they have suspended all international mail so who knows how long the replacement will take...
Re: RZ250 Rebuild!
Posted: Fri Jan 27, 2023 9:51 am
The mail is restarting now (systems were hacked) and they will start accepting parcels again soon, the backlog is clearing now, but i expect people will swamp it again quickly. I have stuff im waiting for as well sadly.
Re: RZ250 Rebuild!
Posted: Wed Feb 08, 2023 7:06 pm
by casabonka
Still on struggle street, got the new ignition coil after spending an extra $60 on fedex and still no luck. Checked all switches, spark plugs, cdi and just won’t start.
All out of ideas now
Re: RZ250 Rebuild!
Posted: Wed Feb 08, 2023 10:51 pm
back to the start then...
Do you have spark?
If not then you need to trace the ignition system to find out where it fails to proceed. These are pretty simple bikes, if youve swapped lots of the ignition parts (CDI, stator, coil) already then its in the wiring or switches. make sure youre getting power where you need it.
Re: RZ250 Rebuild!
Posted: Thu Feb 09, 2023 8:08 pm
by casabonka
JonW wrote: ↑Wed Feb 08, 2023 10:51 pm
Do you have spark?
No, no spark.
Re: RZ250 Rebuild!
Posted: Thu Feb 09, 2023 8:11 pm
by casabonka
Does anyone know what output voltage of the ignition coil should be?
