Hi,
Does anyone know how to adjust the spring preload on a RZV500R?
I can see the damper adjustment on top of the forks (four positions), but not the spring pre-load.
Cheers, Markus.
RZV500R Front Suspension Adjustments
Re: RZV500R Front Suspension Adjustments
I don't think there is a preload adjustment on the RZV. I believe there is a spacer at the top of the fork (not in the RZ though), a longer spacer would be my guess.
41mm fork?
