RD350LC L/H Barrel
Posted: Tue Jun 23, 2015 6:09 pm
by DuncanB
As above. Come on... any of you hoarders got an odd L/H barrel kicking about you want to turn into good hard cash? Untuned 1 model would be lovely! Smaller the bore the better ... I ain't asking much.
Re: RD350LC L/H Barrel
Posted: Sat Jun 27, 2015 6:52 pm
by mboddy
I have one. Ports look stock size. Knife edged transfers. Not sure of size until I measure but it will need rebore due to scoring.
Posted: Sun Jun 28, 2015 4:55 pm
by mboddy
I have two. The one I previously described is less than 65mm but will need boring to 65.25mm or 65.5mm to clean it up $100. The other is totally standard ports good 64mm bore probably able to use without boring - but it has damaged exhaust stud area - ie. one side has been helicoiled - the other has a broken stud stuck in and someone has cut a piece of the alloy away to help remove the stud but has failed. If I was you I would remove the broken stud and remove the helicoil and get both stud holes welded and a new thread tapped. Still easily worth $200 as is I reckon. You can have both for $250 if you want. Mark
Posted: Mon Jun 29, 2015 9:33 am
by mboddy
Here is a pic of the damaged cylinder stud area.
Posted: Mon Jun 29, 2015 9:43 am
by mboddy
Here is a pic of the minor knife edging of the transfers and marks in the bore of the larger cylinder.
Posted: Mon Jun 29, 2015 6:39 pm
by DuncanB
PM'ed you...
Posted: Mon Jul 13, 2015 8:58 pm
by DuncanB
Sorted... Thanks Mark.
Posted: Tue Jul 14, 2015 8:49 am
by mboddy
Any time Duncan
