Pulling apart my next project. RZ250 w/350 pistons
Posted: Wed Mar 30, 2016 9:24 pm
				If you have been following my other thread about the RZ250 you will know it's now parked up in the corner waiting on the fairings and tank to be done. So onto my next basket case.
I acquired another RZ250 F1 that has had a set of 350 barrels added. Looks like it had been run like that for a while but something went seriously wrong and I'm stripping it down. When the head came off I found one piston had metal bits inside it and as you would expect a nasty pitted surface on the piston itself.
And a comparison shot of the head showing a different operating burn.
You can see the pitted cylinder clearly.
I don't know where the bits have come from but the crank doesn't make a full circle so I suspect when I get to it, there will be something broken off or jamming it. I'll send it off to Link when it's out.
So now question time.... Do I measure the piston or pots to find the current piston size? Both pots measure 64.44 or 64.51 if I put a little pressure in the calipers. I'm guessing I have a 64.5 2nd oversize - could someone please confirm before I order the new piston kit.
Thanks
G
Thanks
G
