				How much oil in LC forks?
				Posted: Fri Mar 12, 2021 4:27 pm
				How much oil do you guys out in your standard LC forks?
Mine are rebuilt with new seals but seem a bit saggy.
				Re: How much oil in LC forks?
				Posted: Fri Mar 12, 2021 10:09 pm
				by Ozhammer
				I use the air gap method personally D, although I would have to check my service manual to quote you the actual figure. I also use 10wt oil to firm up the action.
HTH
				Posted: Fri Mar 12, 2021 11:22 pm
				+1
you can add more oil if you think it will help, but go easy. Its probably the springs that are toast tho.
				Posted: Sat Mar 13, 2021 12:49 pm
				Yeah, I’ll have the forks out again and measure spring length, but you’re probably right regards tired springs.
				Posted: Sat Mar 13, 2021 11:50 pm
				almost all yam springs were too weak when new, they will almost certainly be short and weaker now
