Suzuki RG 500 Ignition Coil Connections.
square4
Post by square4 »
HI.
In regard to the Primary coil connection terminals which are marked Positive (+) and Negative (-) respectively.
(1) What are the correct connection positions for the Ignition Coil loom wires ( White and White/Blue trace) ?
(2) Is there any detrimental effect to Ignition System components if they are reversed.
Thanks
