VJ22 help WTF
Posted: Wed Jun 15, 2011 6:53 pm
by HM31A
ok just fitted a sh engine to the rgv-pv shit itself and the cylinder
have the bottom cylinder not firing strong and top cylinder firing strong - exhaust pulses coming out of the end pipes
i have fuel dripping out of the exhaust port of bottom cylinder onto the ground
what i have done to check
replaced plugs with new
replaced bottom coil
replaced carbs
bike starts first kick
engine will run strong with bottom plug lead removed
engine will run not strong with top plug lead removed
it looks like something wrong with compression me think but i dont have a tester
will a 4 stroke compression tester work on a 2t and is the procedure the same me ask
cheers mike
Re: VJ22 help WTF
Posted: Wed Jun 15, 2011 9:06 pm
yes, same tester, same procedure,
are you getting a decent spark on bottom cylinder?
I guess thats your first question which you need to ask yourself to determine whether you've got a fuel/compression issue or an electrical issue
Re: VJ22 help WTF
Posted: Wed Jun 15, 2011 11:54 pm
by HM31A
cheers for jeram
changed the coil and plug so iam confident thats eliminated
Re: VJ22 help WTF
Posted: Thu Jun 16, 2011 1:14 pm
would be looking at the CDI (not SAPC) unit , I would be swaping that to begine with. Seek out anyone who has installed a Ignitech/Zeel as that become redundant then
Re: VJ22 help WTF
Posted: Thu Jun 16, 2011 3:17 pm
by HM31A
2TInstitute wrote:would be looking at the CDI (not SAPC) unit , I would be swaping that to begine with. Seek out anyone who has installed a Ignitech/Zeel as that become redundant then
ok
thanks for that
just done a ct and got 140psi out of the weak cylinder and 120 out of the firing cylinder
work that out!
next track down a cdi for testing
cheers all
Re: VJ22 help WTF
Posted: Thu Jun 16, 2011 11:05 pm
by HM31A
ok
replaced the cdi unit and pick up coils with no change in the situation
Re: VJ22 help WTF
Posted: Fri Jun 17, 2011 10:47 am
are you using resistor plugs and caps?
Re: VJ22 help WTF
Posted: Fri Jun 17, 2011 11:08 am
by HM31A
thanks for the reply and help
2 plugs ive used are BR9ES and BR9ECM
so yes they are resistor plugs but the caps are standard suzuki so i dont think they are resistor caps
though ive changed the bottom coil with another with no effect i might swap the top coil over to see if it makes a difference
cheers mike
Re: VJ22 help WTF
Posted: Fri Jun 17, 2011 1:31 pm
try non resistor plugs as every rgv plug cap I have measured is 5k Ohms
Re: VJ22 help WTF
Posted: Fri Jun 17, 2011 1:57 pm
by HM31A
thanks for that
i will order a new plug
cheers mike
Re: VJ22 help WTF
Posted: Fri Jun 17, 2011 10:50 pm
by HM31A
OK I FEEL LIKE A RIGHT DICK
sorry for not giving the full story but i forgot to say i fitted a set of pipes i had lying around i picked up with a project bike and installed them as they had some nice stingers fitted
so after thinking for a bit that was what the problem was
blocked stinger-just imagine all that backpressure
shall fit another pipe on the next day or two and should work well
Re: VJ22 help WTF
Posted: Fri Jun 17, 2011 11:00 pm
oh well, atleast you got it sorted mate
bit of wasted money on your part though, I guess youve got a good pile of spare parts now
Re: VJ22 help WTF
Posted: Sat Jun 18, 2011 12:42 am
Your 'expert stroker' status might be revoked
Re: VJ22 help WTF
Posted: Sat Jun 18, 2011 4:51 pm
by HM31A
2TInstitute wrote:Your 'expert stroker' status might be revoked
trouble is i got that from posting not diagnoising
different pipes on now and runs a dream
lucky i had all those parts lying around
thanks for the support
cheers all
