Page 1 of 2
				RS125 cdi
				Posted: Mon Nov 14, 2011 10:32 am
				by AlanE2
				I have euro 2 spec cdi/rave controller, does anyone know if the annoying dip in power at around 5-6k rpm can be eliminated?
It has the bridge broken in the cdi so it revs past 8k but other than that stock.
I'll be putting Gianelli pipe and rejetting soon but that dip at 5k would still bug me.
Will a Zeeltronic or similar be the only way past this?
Alan
				Re: RS125 cdi
				Posted: Mon Nov 14, 2011 5:04 pm
				for the money you could get for your stock CDI, you could buy a zeel/ignitech and have change left over.
wont just eliminate the flat spot it will also be the single best modification on your bike.
				Re: RS125 cdi
				Posted: Tue Nov 15, 2011 7:25 am
				+ 1
				Re: RS125 cdi
				Posted: Tue Nov 15, 2011 11:29 am
				by AlanE2
				Can you program the zeel to open the power valve at 2 different rpms?
not sure how important it is as the std cdi opens it at 2500 and 8000.
i think the 2500 open is to self clean?
2TInstitute: when you removed the restrictive snorkel and saw a drop in hp, did you remove it entirely of replace with a less restrictive one?
				Re: RS125 cdi
				Posted: Tue Nov 15, 2011 12:26 pm
				Removed to snorkel entirely, the snorkel is NOT 'restrictive' at all. The dyno does not lie.
The early version of the Zeeltronic software could not do that but Crash Dummy(Gary) has been in constant contact with Borut and he has updated the software /wiring diagram to do this and to relieve the tension on the cable once opened fully.
				Re: RS125 cdi
				Posted: Tue Nov 15, 2011 12:48 pm
				2TInstitute wrote:+ 1
no plus one required, I was quoting you there haha
				Re: RS125 cdi
				Posted: Tue Nov 15, 2011 12:51 pm
				by AlanE2
				cool thanks for the info. i'll contact Borut at Zeel as this sounds like the way to go.
Are you guys using the handheld programmer or usb?
				Re: RS125 cdi
				Posted: Wed Nov 16, 2011 7:09 am
				Both, PC is great at dyno or home, the handheld is great in the field
				Re: RS125 cdi
				Posted: Wed Nov 16, 2011 9:39 am
				but then again, for the price of boruts hand held device you can get yourself a chinese netbook computer thats super compact, 6hr battery life, windows 7...
Iv had one of them for 12 months without any dramas.
fits in the smallest of backpacks.
				Re: RS125 cdi
				Posted: Thu Nov 17, 2011 4:31 am
				by AlanE2
				wow-you can get a win7 netbook that cheap? i've been quoted 57euro for the handheld controller.
did you guys splice the wires to the zeel using bullet type connectors or get a multi-pin plug?
				Re: RS125 cdi
				Posted: Thu Nov 17, 2011 6:14 am
				ok, 57 is cheaper than I thought... the netbooks are about $230
but for 230 you also get a computer that does almost everything a normal laptop can.
up to you
				Re: RS125 cdi
				Posted: Thu Nov 17, 2011 7:19 am
				AlanE2 wrote:wow-you can get a win7 netbook that cheap? i've been quoted 57euro for the handheld controller.
I just cut and solder then cover with heatshrink
				Re: RS125 cdi
				Posted: Thu Nov 17, 2011 2:47 pm
				by AlanE2
				just one more thing, how long have you 2 (jeram and 2T) had your zeels for?
any reliability issues? my rs125 is used everyday-wet or dry.
there must be a few other users out there down under.
				Re: RS125 cdi
				Posted: Thu Nov 17, 2011 5:22 pm
				Im igntech... soon to try a zeel on another project soon though.
2Ti's the best one to ask about that.
Iv heard about guys using zeels and ignitechs on triumph twins having reliability issues (bout 500hr life) but I suspect that is to do either
-vibration damaging ignition OR
-wired up wrong
still 500hrs work of increased performance for only a couple hundred bucks... cant complain.
				Re: RS125 cdi
				Posted: Fri Nov 18, 2011 7:24 am
				been usingbeen using ignitech/zeel since 06, any issues just sent back repaired and returned. Just get one there is nothing to worry about
