				RZ500 Sparkplugs
				Posted: Fri Jan 15, 2010 10:57 am
				by wheels999
				Could someone please tell me what make / model spark plugs I should be using in a RZV500?  Whats standard?  Any recommendations other than standard?
Also, what is the best (ie. cheapest) place to buy them in Sydney?
Cheers, Markus.
				Re: RZ500 Sparkplugs
				Posted: Fri Jan 15, 2010 5:12 pm
				You'll struggle to find someone that stocks them in Sydney.
NGK BR9HS are standard.
They are a short series. MCAS ordered them in for me.
				Posted: Fri Jan 15, 2010 6:54 pm
				by wheels999
				Thanks for that!
				Posted: Fri Jan 15, 2010 7:31 pm
				by matty
				This is not going to help you Marcus but might help someone here in Melb.
Stafford Yamaha in Heidleberg stock these plugs and are the only shop I can find who do. They say that they will continue to stock them as long as I continue to buy them buy the box
				Posted: Wed Jan 20, 2010 10:32 am
				by wheels999
				Talked to MCAS (Auburn).  They don't carry "R" (resistor) type plugs but  they do have the ones with out the R, ie. B9HS.  They said it would take over a month to get the BR9HS in.  Sounded to me like they're overstocked on the non-resistor type ones...
I really dislike MCAS, they've pissed me of a number of times despite spending thousands of dollars with them.
Are the non-resistor ones ok to use?
				Posted: Wed Jan 20, 2010 1:03 pm
				The R's (resistor) were to stop interference with the YPVS system I believe.
I'm using non- R's in my 500 and I don't seem to have any issues, but I'm running the Zeeltronic PV controller which may have better noise supression.
Not sure.
You will get better spark from the non R's if they don't interfere with the YPVS.
You might also be able to go higher resistance in the caps and not bother with R's in the plugs, but not sure if its possible to source caps with higher resistance than standard.
				Posted: Thu Jan 21, 2010 5:09 pm
				by ash33
				It shouldn't be a problem running non resistor plugs because you can always fit a end cap with a resistor.
				Posted: Fri Jan 22, 2010 6:47 am
				Yes, but the 500 was supposed to be resistor plugs AND resistor caps.
				Posted: Fri Jan 22, 2010 8:15 am
				by ash33
				Same as the RGV then
I'm told the Jap manufacturers liked to be a little over protective in this area and only put the resistor cap on just in case some one fitted non resistor plugs?
I guess the only way to really know is test the spark on the non resistor plugs then test the the resistor plugs to see if there is any significant voltage drop.
				Posted: Fri Jan 22, 2010 9:54 pm
				Yeah... as I said, I'm running non resistor plugs with NGK resistor silcone caps and I don't seem to have any issues.
Although sometimes when my bike is running I can't open the garage with the remote
				Posted: Fri Jan 22, 2010 11:04 pm
				by wheels999
				hybrid wrote:Yeah... as I said, I'm running non resistor plugs with NGK resistor silcone caps and I don't seem to have any issues.
Hehe...
Found them at Supercheap Auto believe it or not.  They are sold as marine plugs for Johnson outboards.  Bit dearer than I would have liked, but oh well. (about $5 each)
When I checked the existing plugs on the bike they were actually nearly brand new B8HS...
Shame about the blown headgasket(s)... it started quite easily and ran pretty well.
I'm starting to think I might keep it... its a really nice bike.
Cheers, Markus.
				Posted: Sat Jul 03, 2010 11:04 pm
				by Peachez
				Been looking at NGK and it looks like you might be able to use the BR9HIX Iridium plugs.
http://www.ngkspark.com.au/sparkplug_bi ... del=RZ500L
I will be looking at contacting them & asking them about availability sometime soon.
				Posted: Sun Jul 04, 2010 5:51 pm
				by w3a51l
				SuperCheap in Blacktown had BR9HIX plugs in the cabinet two weeks ago.
