				RZ Powervalves  needed
				Posted: Mon Nov 12, 2012 12:24 pm
				by jools
 I knew I'd need to do powervalve bushes and seals on my '83 RZ 250, but I need the actual powervalves too. A bush retainer has failed, allowing a bush to move out of its housing, and so everything's got misaligned and worn, including the centre joiner.
Anyone got a set of powervalves in VGC for sale? (I'll get new bushes and seals, it's the actual powervalves and centre joiner I need).
I need pistons and rings .75 oversize too, can anyone advise the best source for a piston set? Obviously cost is an issue, but I don't want to risk using crap stuff.
Cheers,
Jools
				Re: RZ Powervalves  needed
				Posted: Mon Nov 12, 2012 1:32 pm
				I have a set, are you going to the creek on the weekend? if so I can give them to you then. I dont have the joiner though. Mitaka pistons from Yambits are the go.
				Posted: Mon Nov 12, 2012 1:41 pm
				by jools
				Hey that's a quick reply, thanks! Unfortunately I'm in Vic so it would have to be by mail. Are they 250 powervalves? (The 350 ones are different I think).
What sort of money do you want for them?
Yambits don't have the .75 oversize pistons I'd prefer, I'd have to go for 1mm  over, I'll think about this one. Thanks for the tip mate.
Cheers,
Jools
				Posted: Mon Nov 12, 2012 2:37 pm
				Email Yambits they might have them but not on the site displayed. You can have the PVs just cover the postage, they are 250 ones. I had a look they are both fitted in left cylinders, are they handed or interchangeable.
				Posted: Mon Nov 12, 2012 7:19 pm
				by jools
				Great, I've emailed you direct.
From what I can see they're the same -interchangeable, left and right, so they should be fine.
Thanks a mill'
-Jools
				Re: RZ Powervalves  still needed
				Posted: Mon Nov 12, 2012 9:07 pm
				by jools
				Just checked and it looks like the LH and RH are different, so EPA's 2 RH ones won't do it.
So still looking for a pair, plus the centre joiner.
-Jools
				Posted: Tue Nov 13, 2012 6:19 am
				No worries if you find a right side let me know and I will send a left.
				Posted: Tue Nov 13, 2012 8:22 am
				by fred99999au
				Given it is flavour of the month, TSS apparently sells valves and bush sets. I have tried to find the bushes from standard bearing suppliers and they are made of unobtainium based on my initial research.
http://www.twostrokeshop.com/two_stroke ... shandjoint
				Posted: Tue Nov 13, 2012 11:41 am
				I have his PVs in my RZ and they do work well but I had to wait over 6 weeks to get them even though they were an off the shelf item he said.
