i have used them before on banshee engines
i just bought some v force 4 reeds and cage for my dt200l..
and might i say that these are a great up grade..
not sure how much over all hpr is gained maybe a couple.. but throttle response is awesome now and it pulls harder right through...
vforce reeds reveiw
Re: vforce reeds reveiw
Hey twinrock. Presumably, this is with your modified CR/DT pipe?
Wonder what difference it would make to a stocky?
Where did you get the reeds from?
Cheers,
Fred
Cheers,
Fred
well no ...i had the reeds on befor the pipe change..i did this on purpose so i would know what changed what..!!!
What part number?
they are standard blaster editions.. how ever i have the first model dt200L..identical to the blaster as for the dt200r or wr200 i am not sure if the reed cage is the same or not..i can measure it to compare with yours tho..
how does ur dt compare with wr..performance wise
