New member. New project.
Posted: Sun Nov 25, 2012 9:38 pm
Hi All,
I have been a member for awhile and thought I would say G'day and ask a couple of questions, if I can
I live in North QLD and picked up this basket case 03/84 RZ350 for the princely sum of 2 cartons of Carlton Mid stubbies
It was sitting in a farm shed for at least 8 years and looks very sad. (click thumbnail for bigger image)
[center]
[/center]
I picked it up in January and resisted starting to tear it down due to restoring a 1990 DR650RS which was in about the same condition as the RZ. The DR is 99% finished and I decided to look into what the RZ needs and if it will be worthwhile doing a full resto or stripping it for parts. It needs a total restoration and it doesn't run because there is no spark. The previous owner said it would run on Aerostart
Probably wont be worth much as parts either, seeing as everything is stuffed
The only missing part is the belly pan.
On to the questions...
Matching numbers refers to what exactly? For this bike, the engine number starts with 1AH, VIN starts with 35G, and the barrels are 31K
Can the shock be rebuilt?
There is a rubber belt under the battery, which I presume is for setting the shock preload. Is there an after market alternative?
The rear brake caliper has a Scandinavian Brake System (SBS) sticker on it. Is this stock?
Is there anyway to tell what colour scheme it originally had? With the black frame, I'm guessing it looked like this:
Looking at that photo again, I'm wondering if the barrels and head have been changed, seeing as they are black in the photo and mine are bare alloy.
That's all I can think of at the moment, and I'm certain there will be more questions to come.
Cheers,
David.
[center]
[/center]
Cheers,
David.
