RZ500 rear cylinder bank cooling mod
Posted: Thu Jan 28, 2010 9:47 am
by wheels999
I've been reading a bunch of the cooling mod threads on http://www.rzrd500.com and I can't get a clear picture of how this is done.
Is there a guide with pictures somewhere... rathan than four pages of bickering about stealing ideas and profiting unfairly etc...
Cheers, Markus.
Re: RZ500 rear cylinder bank cooling mod
Posted: Thu Jan 28, 2010 12:28 pm
Cooling mods to the rear cylinders?
What you do is drill and tap an inlet into the top case where the water jacket goes in. You then remove the rubber plugs from the barrels, and this is supposed to allow flow around the exhaust ports.
Posted: Thu Jan 28, 2010 12:35 pm
by wheels999
hybrid wrote:Cooling mods to the rear cylinders?
You don't sound convinced. Waste of time?
Posted: Thu Jan 28, 2010 2:58 pm
Note the fittings in the top case.
They are not hooked up in this pic, but you would basically "T" them together and return to the radiator.
Is it worth it? It's a hot topic. Look, if you've got the engine out, why not do it... it certainly can't hurt.
I've not had an issue with mine, but guys have shown that the rears certainly get hotter than the fronts. Some may say that is purely down to them being higher, and also having less exposure to airflow.
I can't say for sure either way, so I'd say do it if you've got the engine out and have the inclination.
