Digital speedo for RZ 500 with R6 front end
Posted: Wed Mar 27, 2013 6:57 pm
				I have fitted a motogadget mini digital speedo to my bike because i have the R6 front end.
I have connected the speed sensor to the back wheel.
I have NOT connected the tacho function wire as it is not needed
I have connected the power to a switched positve and connected the earth.
While your riding the speedo works fine up till the tacho reaches 5500rpm then it goes haywire with speed readings of, for example 484,358,433 klms per hour, drop back below 5500rpm its works fine.
If you sit with the bike in neutral and rev it above 5500rpm it does the same thing, then when it drops below 5500rpm it reads zero as it should .
It seems that there is some sort of electrical interference at high RPM.
I have insulated all the wires properly.
It is installed as the instructions advise.
I have contacted motogadget but they were no help. I thought at $300 for the unit there would be some sort of after sales service but no.
Can any of you electonic guru's help me???
