				FOUND: RZ clutch cable bracket for crank case + other bits
				Posted: Thu Apr 04, 2013 4:47 pm
				Hi Guys
Steve at Two Stroke Shop is stuffing me around.
I purchased a clutch cable bracket (the one that mounts the cable to the crank cases) a month ago.
I was told that he had serveral in stock
I payed for it
He then said he had sent it
Two weeks later after I harassed him he said he infact  never had one.
He ordered one from Yamaha 2 weeks ago
Still no sign of receiving it.
I usually stick up for Steve when people pick on him (regarding small parts, not the TSS500 issue). But the last few times it has taken some heckling to get the parts I need.
I could have ordered it from Yamaha AUS or USA and received it by now.
Anyhow does anyone have one kicking around?
Even if its on a bike collecting dust, I will pay for it + extra if you want to order a brand new shinny one for your bike and are happy to wait for it to turn up
This is the last part I need to get the TZR421 going which is frustrating.
Other parts Id like to get my hands on, but not in such a rush is an OEM clutch lever and perch and an OEM clutch cable
(although its an RZ part, it is the same as many other models)
Thanks guys,
If I dont get a response before the weekend Ill just call up my local yamaha dealer.
				Re: URGENT: RZ clutch cable bracket for crank case + other bits
				Posted: Thu Apr 04, 2013 5:28 pm
				whats the p/n
				Posted: Thu Apr 04, 2013 7:02 pm
				Got a few clutch cables but they are pretty nasty, I would get a new one if i was you, they say the 'shee is the same and will work fine if you have low bars.
The clutch bracket is the 'n' shaped one with the wire sticking out of the edge is it? I may have one, but it wont be pretty and probably bent - they usually are it seems. Annoying as its not an expensive part Jeram it must suck to be waiting for this little thing
				Posted: Thu Apr 04, 2013 7:27 pm
				Yeah 14 bucks !
Yeah it's the little wire bracket that you speak of
I called citywest Yamaha and for just over 50 bucks he can get me the bracket plus lever perch and lever.
But I would have to wait 2 weeks for it to come from Yamaha Japan.
There are officially no more rz clutch cables anywhere Acording to Yamaha, but I have an aftermarket one.
Lozza ill track down the numbers tomorrow I suspect I can get the bits cheaper in the USA, but I don't want to wait for bits to come from Japan to USA then wait for postage from USA to AUS
				Posted: Fri Apr 05, 2013 7:12 am
				by fred99999au
				I prolly have one on that spare engine or two givvus a bell this arvie.
				Posted: Fri Apr 05, 2013 10:33 am
				Who woulda thought, the part I need could be just 500 meters from my house!
yeah Ill be sure to give you a bell this arvo!
				Posted: Fri Apr 05, 2013 10:34 am
				by the way, I've still got a few of your tools and still have to give you that fancy clutch bearing I got for you so Ill have to remember to bring them over tonight
				Posted: Fri Apr 05, 2013 4:03 pm
				by L.B.
				Got spare new cables &  a bracket if ya need it. Ill even express post it,been waiting to hear/see this thing  running lol.
Parts like cables etc you cant go past bob_yp on eblag. Top guy,if he hasnt got it he can get it at pretty good prices.
				Posted: Sat Apr 06, 2013 11:17 am
				Thanks mate
 much appriciated.
Thanks to Fred, I was able to get the bracket I needed last nite
Many thanks mate!
I've got an aftermarket cable sorted which will hopefully work fine, The only bits Im hunting for now is the clutch lever perch, Clutch lever, and the clutch lever adjuster bolt/nut
I can get these from yamaha but will be 2 weeks for them to come from Japan.
So if nobody has a lever, perch and adjuster this weekend, Ill order it first thing monday. It will take me 2 weeks to finish off the rest of the bike so will probably be perfect timing
Things to do:
-pop the carbies back on
-pop the airbox back on
-install the EGT probes and guage
-put some foam under the fiberglass seat so it doesnt crack when It pushes against the subframe
-paint (I want to try White plastidip with a new glossifier and pearl top coats they have now)
-tidy up the wiring loom a little
-get a lithium ion battery and mount it on the bike
So just lots of little jobs to go, nothing serious.
Then Ill be taking her to the drags to get the jetting set up!
so yes, if anyone has a lever perch or adjuster let me know ASAP
				Posted: Sat Apr 06, 2013 11:24 am
				L.B. wrote:Got spare new cables &  a bracket if ya need it. Ill even express post it,been waiting to hear/see this thing  running lol.
Thanks mate,
I sent bob_yp a message to see if he can help with the remaining bits that I need.
				Posted: Wed Apr 10, 2013 11:30 pm
				by fred99999au
				funny thing was, I prolly have a clutch perch and lever on my other spare RZ at my mate's place in Lara.
				Posted: Thu Apr 11, 2013 1:03 pm
				Iteresting, if my set up gives me any dramas, ill buy them off you!
funny thing is, I still havnt got the parts from Steve, not that I need them anymore!
