Fowling plugs
Fowling plugs
Have 2006 YZ250, worked fine in hunter area, took to luee, fowled 3 plugs WTF??
Re: Fowling plugs
Jetting is the answer look in your manual
Re: Fowling plugs
believe it or not I bet your rear silencer needs repacking!
Re: Fowling plugs
why do you say that pleaseStankflapper wrote:believe it or not I bet your rear silencer needs repacking!
Re: Fowling plugs
Not sure how that would be related.TZR250 wrote:why do you say that pleaseStankflapper wrote:believe it or not I bet your rear silencer needs repacking!
Fouling plugs can happen for a number of reasons;
* low rpm operation for extended periods, plugs don't get hot enough to burn of oil residue
* too much fuel, too little air (jetted too rich, or air intake restricted (very dirty air filter), air density (e.g.. cold air / low altitude = higher density = leaner running, warmer air = richer running
* wrong plugs (too cold)
Re: Fowling plugs
Hi dont forget the rh crank seal sucking all the gearbox oil into the engine, always a suprizing source of fouled plugs. Link
