Couple of RZ parts needed
Looking for a part?
Hi all, I am looking for a couple of parts to finish off some projects...
1, RZ350 85 screen, the full fairing one. uncracked OEM is what I need, i dont mind light scratches or hazing / fading from the sun and am happy to look at what youve got and see if i can bring it back from the dead. same screen fits the 500 in case you have a 500 one lying about...
2, 2T Oil tank with good mounts (i think all RZ years use the same tank) I dont need the switch, just the tank.
3, undamaged (not cracked) rear light bracket for the triangular light models, ie 83-85.
Can maybe swap for some other RZ parts depending on what you need...
Re: Couple of RZ parts needed
My frendly local wrecker deffo has the bracket, don't remember seeing the oil tank but its possible. I'm off to Kangaroo Island on Sunday, so won't be around for a week after that. Will check if you're in need.
Thanks mate defo need the bracket, probably posting the tank would be crazy money tho. Ive found the tank is available new still for US$53!
I'll zip in on Saturday morning, see what I can find :)
Many crack, I know what you mean, have had to replace on one of my bikes. I'll try to get one with the rubbers and spacers.
Jon, got you a nice green bracket with good rubbers, no cracks and only a slight touch of surface rust in the two hidden lower crevices. Spacers nowere to be seen and I checked all the brackets he had in. Nice bracket though.
Won't be able to post it til monday week, hope you can wait that long.
Thanks! Thats superb, speed isnt an issue, this is for my 83 project :) Just drop me a PM with what I owe you and your bank dets and I'll fix you up, cheers m8!
Oi, Jon, check yer PM
