The fuel tank had some rust in it. twice whilst riding the motor would stumble and when i pulled over the carbs where overflowing from rust in the needle and seat. (glad i took a back pack with tools). I've prepped the tank, will seal it in the next days.
The front disc is is heavely grooved and now is only 3-3.5mm thick. so this needs to be replaced. Been looking at metal gear front disc for 180 delivered and using there sintered brakes, Any opinion on there product? Also will fit a braided front line.
The chambers are not original and i have no idea of brand. I'd say they are of japanese origin? They do fit well and powers good, peaking around 10g.The mufflers are junk, they are rz350n i believe, not in very good condition. I'm looking at Tyga end cans on ebay, the price is good and they look like they will fit? Any opions on them?http://www.ebay.com.au/itm/Tyga-Perform ... ae7&_uhb=1
With the motor out i pulled out one of the reed blocks. The reeds are fiber, again not sure of the brand. Also discovered the front sprocket is 15t i believe 14t is standard. Chain and rear sprocket are in good order so i think i'll try a 14t up front then go from there.
I would like to pull the cylinders of to see if they've had work and check the condition of pistons and bores. The motor runs well compression is at 125psi and the budget is so small i'll leave it alone for now and just fix up the above mentioned problems and tidy everything up. This is my first tzr and i'm impressed with the design of the frame and the lay out of the engine. Looking forward to getting it back together and taking it to the track.
