best performing stock pipes??
twinrock
Post by twinrock »
What are the best performing stock pipes.. I currently have 350 f2 pipes..they feel soo lethargic..and sound terrible..I like the look of early cigar pipes..but also lookin at cutting the mufflers off the f2 and putting better less restrictive ones on..just lookin at options for stock set up..befor I look at chambers..Thanks
Re: best performing stock pipes??
the ones you have are the best really, maybe they need a good clean out with caustic soda?
twinrock wrote:What are the best performing stock pipes.. I currently have 350 f2 pipes..they feel soo lethargic..and sound terrible..I like the look of early cigar pipes..but also lookin at cutting the mufflers off the f2 and putting better less restrictive ones on..just lookin at options for stock set up..befor I look at chambers..Thanks
Keep the cans and gut the pipes would be better.
"they feel soo lethargic" I not sure what you are comparing to or what you expect from the poor old 2t 350 but you might have other issues.
But really the answer is properly designed pipes. And they can be quiet and still produce good power.
There was long and dare I say "exhaustive" testing done on most pipes available on a dyno by some of the fellas on the UK LC forum which seems to back up what Jon an OZ are saying, worth a read.
twinrock
Post by twinrock »
Thanks guys..Yeah I have cut pipes open befor to remove all the internal linings..its messy work..Including a tzr 2ma pipes I also redid the end cans too..it was an Improvement..and lightened up quite a bit..
