What makes the banshee 1st gear so good?
Probably longer.
Here they are nearly done. Steve sends a kick in the shin ehDOC03 wrote: Expansion chambers Lozza is knocking up.
hi
lozza can you show us a pic of the header pipe flange
tims pipes at towmnsville are they yours
as they had a inner sleave & a outer 1
then the pipe slipped down in the middle
looked a good fit in to the header
cheers peet
cheers peet
Hey Lozza,
do you know if the belly pan fits with your pipes installed?
Peet, Tim has an old H100 pipe of mine I gave him I don't remember much about the flange(or the pipe for that matter) that was too many pipes ago
I usualy make the pipe fit inside the flange, I now get them all machined and laser cut.
Jeff I dunno if they would fit with the belly pan, maybe see the other Pete when his are done??
421cc of complete madness.
Nice looking pipes Lozza...
