Rdlc speedo parts free to good home
Hi guys I have a rdlc speedo in parts if anyone needs anything. It was all together but I pulled it apart to try to see if I could clean up the numbers that yellow off but no luck just took off the numbers lol. It was a spare one that came in a box with the bike so if anyone needs some parts sing out. I scored nos speedo & tacho so no use to me as I have another used complete set if needed.
Cheers Rob
Cheers Rob
Re: Rdlc speedo parts free to good home
Hi Rob, just snagged a 350LC and the Perspex on the idiot lights looks crazed. I haven't seen it in the flesh yet though. Are you in Sydney?
I'd be interested, ironically probably to put on an RZ with smashed kidney clocks. Could you message me an image or two and what you're looking for?
Guys this is the speedo unit only not the plastic housing that holds the speedo & tacho
I will take some pictures up tomorrow for everyone
Here' the pictures I'm away until after easter so may not reply until I'm back. All I ask is the money to cover postage if you want the parts.
- P1010573.jpg (73.05 KiB) Viewed 6018 times
- P1010571.jpg (64.51 KiB) Viewed 6018 times
- P1010572.jpg (41.98 KiB) Viewed 6018 times
and the rest
- P1010576.jpg (70.48 KiB) Viewed 6018 times
- P1010574.jpg (47.93 KiB) Viewed 6018 times
The housing looks intact, my LC's has broken lugs, so I'm stll interested.
I had a rev counter with broken lugs, I repaired them but later found a body with them intact in a box of spares, much better.
This is a great gesture Rob, nice work!
What method you use for repair Jon?
You can clean it up and buy a decal to put over the existing lettering, that's what I did with mineclod wrote:Hi Rob, just snagged a 350LC and the Perspex on the idiot lights looks crazed. I haven't seen it in the flesh yet though. Are you in Sydney?
Steve
Hi BRG1200
Yes the housing is in good condition tabs are not broken pm me your details and we can sort out postage.
The clock face wasn't the issue its fine it was the tenths of kms dials they go from white to yellowish.
Thanks Jon just happy to help out if I can. Wife just doesn't know how much this is costing for the parts bin haha
Thanks Rob, will do!
haha, yeah probably best not to write too much down Rob
D, I welded some flat plastic on with a soldering iron and then trimmed back with a dremel with a burr.
Was repairing bits of plastic on the Missus car today with a soldering iron in same way. Minor nudge, lots of plastic :-/
Will try the bigger soldering iron tomorrow.
