yep I guess we have got off topic a bit.....
The egg dyno sort of evolved from a search for a method to accurately measure modifications. It started by trying to gauge where for example the distance travelled to reach a particular speed was obtained.
In Drag racing the
speed obtained at the end of the strip is a direct indicator of horsepower..... whereas the time is related to traction, gearing, weight transfer, rider ability and many other factors....(as well as power).
So ignoring the time and only looking at the speed, we can gauge if we have increased horsepower reasonably accurately.
Extending this a bit, the shorter the distance it takes to reach a fixed speed, the greater the power.
Now how to judge where you actually are when you reach that speed..... we tried distance markers and tried to estimate where you were whilst looking at the speedo at the same time......not repeatable enough...then we figured that we could just drop something from the bike at the exact time we reached the speed......something that would stop immediately, not slide or roll, something that would mark the exact spot where the speed was reached.........
Bearing in mind this was done on a public road, at quite err.... reasonable speed, and if err.... official persons turned up to see what was happening, there was no evidence other than a few splats of dropped egg on the road
So each time the egg trail got closer to the start of the test run, you knew that your mod had worked.
Today I would buy a GPS device that I could push a button when the speed was reached, that would tell me the position within a meter or so. The eggs got us to that sort of accuracy 45 years ago
One problem was that after a while we were having to avoid Crows and Magpies.........
Graham
