Nice to see it fired up anyway
CR(M)250AR SUPERMOTO BUILD
Re: CR(M)250AR SUPERMOTO BUILD
My 5 yr old just said "Is that Jeram on youtube?" ..........."It is Jeram on youtube"................"eeeeee Jeram's underpants are showing"
'Pants on the ground, pants on the ground...' haha!
bahhh, still having servo motor dramas.
Im thinking that there is a problem with the ignition as the servo is being spastic.
turn the ignition on once and the servo spins to 2300mV (the max value on the curve, for servo cleaning),
turn the ignition on a second time and the servo spins back to 400mV which is the min value on my curve
start the bike up and it doesnt move at all.
So Iv contacted ignitech to see if they have a solution or can repair the ignition if its damaged.
some testing clips from the weekend.
went pretty well, and top end is very strong
however the mid range is lacking big time due to the PV servo not working and the needle clip being too low making it too rich.
but other than that it was very very fun!
http://www.youtube.com/watch?v=_Rk76UxT ... ure=relmfu
http://www.youtube.com/watch?v=jgFWm9S_BDs
Ill get the jetting a bit closer, get the PV working then head out for one more test like this.
then Ill dyno tune the bike, and then it'l be race ready
