RZ 500
RZ 500
hi
can some tell me if possible the difference between a RD500 and a RZ 500 engine ?
the RD 500 engine number is 1GE-002389
cheers :?
Re: RZ 500
There is no difference... all parts should be interchangable between the models, including RZV.
The RZV was restricted in the exhausts and had different jetting though.
There is evidence of a strange model of engine that had a small flywheel hanging off the end of the rear crank, but extremely rare.
Re: RZ 500
ok
just to clarify and i understand
i have a rd500 engine cases Engine number is 1GE-002389
i should be able to swap my internal from rz500 a engine no 53G-004158
asking as my rz has a hole in the casing
cheers :?
Re: RZ 500
Yes, that should work fine :)
ritza
Re: RZ 500
Post by ritza »
hey also from perth wherebouts are you??
Re: RZ 500
i am in freo
ritza
Re: RZ 500
Post by ritza »
you the guy that bought all the bits?
Re: RZ 500
which bits are those?
Smokers Day Out
ritza
Re: RZ 500
Post by ritza »
the 5 x rz500 worth of bitz 8O
