2TInstitute wrote:
Banshee and LC are NOT interchangeable.
No, the cranks and barrels aren't interchangable, but I didn't think that is what he was asking.
The RZ/Banshee engine will bolt straight into the LC Frame though.
But no, you can't buy just the stroker kit for the banshee and fit it straight into the LC cases.
Ant: they aren't very hard to install, and Borut gives a good wiring diagram/instructions to install. You basically unplug the wires between the pickup and the CDI, plug the pickup into the VCDI, run ignition power to the VCDI, then plug the VCDI into the original CDI. Can't see a reason you couldn't put the RZ CDI into an LC, but who knows if the curve would suit.
You also have to take off the pickup backing plate and elongate the holes so you can set it to around 35 degrees advance. You need to set your static advance to at least the max advance that you will want. The VCDI can't create advance... all it does is delays the spark until the right moment, so it needs to get its signal before the actual spark needs to happen.
DOC03: You should be able to run banshee carbs - the only issue is going to be the manifolds, so it depends how big you go. The RZ and LC manifold hole spacings are the same, so you may even be able to use banshee manifolds anyway. What you have to be careful of is clearance around the airbox etc. I wouldn't go any bigger than 28's on a street LC anyway. Another mod you can do is  get the barrel inlets ported a little to fit the RZ reed cages (which I have done), and you can then fit all the banshee reeds etc, but plenty of guys make decent power from the LC without this mod. The RZ cages/reeds are bigger.
