Been a long time since an update, but thats because nothing major has been done. I've just been doing a lot of fiddly stuff thats frustrating.
Heres the current pic taken tonight:
I've been slowly doing some work over the last month when I have had time.
Some of the items of note:
- Mounted YPVS controller in the front of the fairing
- Raised the radiator higher to give better clearance from front tyre and bottom plugs
- Modified the cable from YPVS controller to oil pump to reach the new YPVS controller location
- Modifed the top triple clamp and ignition switch to fit the standard RZ500 ignition switch
- Fabricated a plate to go above the engine to mount the battery. This will also mount the fuel pump and other items.
- Put some transmission oil (1.6L) in the bike
Whats next?
There is still plenty to do before its ready to fire up, such as:
- Make fuel rails
- Mount ECU, Zeeltronic ignition components etc
- Find a fuel pump seeing as the GPZ1100 pump seized while it sat around doing nothing for a year
- Start the wiring
Its certainly not going to be ready for Phillip Island MotoGP in October like I had hoped.
