The bike is a low km (4,900) jap import and clearly the engine has never been touched. I've been slowly recommissioning the bike but the focus has been the chassis, brakes etc. as the bike started and ran fine when I bought it, though I must admit I did wonder whether I should've had the engine pulled down for an inspection at least.... And I've certainly read before that many (most / all) two strokes need these changed after prolonged periods of inactivity (which obviously my KR has had).
Anyway, the bike is basically finished and has come up a treat, it looks amazing and I'm very happy with it, except on its first little blast down the road it started spitting oil out of the lower pipe muffler, out the end and out the bolt holes that hold the muffler sleeve on. The oil doesn't appear to be two stroke so it must be gear box oil so I assume I have a blown or leaking crank case seal on the front cylinder. The muffler still has noise suppression packing around the baffle and this is soaked in oil.
So, I'm no engine expert but is this the correct diagnosis? If do I guess I'll start pulling the bike apart again!
Appreciate any advice from the experts.
Cheers, Richard
_________________
1983 RZ350K
1984 KR250A
1985 GSXR750F
1989 TZR250 3MA
2010 Street Triple 675
